Acer Aspire E1-510-2500 RAM Card Replacement
  1. Acer Aspire E1-510-2500 RAM Card Replacement, Battery: step 1, image 1 of 1
    • Ensure that your laptop is completely switched off, and disconnected from the power source.
    • Flip the laptop so that the base of the laptop is facing up.
  2. Acer Aspire E1-510-2500 RAM Card Replacement: step 2, image 1 of 2 Acer Aspire E1-510-2500 RAM Card Replacement: step 2, image 2 of 2
    • Insert a spudger into the battery release latch.
    • Slide the battery release latch to the right, this will eject the battery for safe removal.
  3. Acer Aspire E1-510-2500 RAM Card Replacement: step 3, image 1 of 2 Acer Aspire E1-510-2500 RAM Card Replacement: step 3, image 2 of 2
    • Carefully slide the battery out of the battery's home.
  4. Acer Aspire E1-510-2500 RAM Card Replacement, RAM Card: step 4, image 1 of 2 Acer Aspire E1-510-2500 RAM Card Replacement, RAM Card: step 4, image 2 of 2
    • Using a Phillips 1 screwdriver, remove the 9 mm screw which secures the back panel.
  5. Acer Aspire E1-510-2500 RAM Card Replacement: step 5, image 1 of 2 Acer Aspire E1-510-2500 RAM Card Replacement: step 5, image 2 of 2
    • Use a plastic opening tool to carefully pry the back panel from its home.
    • When reassembling, insert the panel from the edge opposite the screw first.
  6. Acer Aspire E1-510-2500 RAM Card Replacement: step 6, image 1 of 3 Acer Aspire E1-510-2500 RAM Card Replacement: step 6, image 2 of 3 Acer Aspire E1-510-2500 RAM Card Replacement: step 6, image 3 of 3
    • Locate the tabs on either side of the RAM card.
    • Push out on both tabs simultaneously to release the RAM card.
    • The RAM card should raise slightly at the unattached edge.
  7. Acer Aspire E1-510-2500 RAM Card Replacement: step 7, image 1 of 2 Acer Aspire E1-510-2500 RAM Card Replacement: step 7, image 2 of 2
    • Carefully remove the RAM card from its home.
Sebastian Taylor
733 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 592
