Acer Aspire E1-531-2438 Hard Drive Replacement
  1. Acer Aspire E1-531-2438 Hard Drive Replacement, Battery: step 1, image 1 of 2 Acer Aspire E1-531-2438 Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Unplug and power down the device before removing the battery.
    • Turn the device over so the back side is facing up.
    • Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
    • Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
  2. Acer Aspire E1-531-2438 Hard Drive Replacement: step 2, image 1 of 1
    • Tilt the side of the battery closest to the orange latch upward.
    • Lift the battery up and out of the device.
  3. Acer Aspire E1-531-2438 Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 Acer Aspire E1-531-2438 Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
    • Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
  4. Acer Aspire E1-531-2438 Hard Drive Replacement: step 4, image 1 of 3 Acer Aspire E1-531-2438 Hard Drive Replacement: step 4, image 2 of 3 Acer Aspire E1-531-2438 Hard Drive Replacement: step 4, image 3 of 3
    • Using the indentation, pry open the access panel with your fingers or a spudger.
    • Remove the access panel to expose the hard drive, WiFi chip, and RAM modules.
  5. Acer Aspire E1-531-2438 Hard Drive Replacement: step 5, image 1 of 3 Acer Aspire E1-531-2438 Hard Drive Replacement: step 5, image 2 of 3 Acer Aspire E1-531-2438 Hard Drive Replacement: step 5, image 3 of 3
    • Grip the plastic tab on the hard drive, then pull to the left to unplug the drive from its socket.
    • Once free from the socket, lift the hard drive up and out of the device.
Jakob Rinkus
965 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 26
All Time: 2,244
