Acer Aspire E1-532-2616 Hard Drive Replacement
  1. Acer Aspire E1-532-2616 Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Acer Aspire E1-532-2616 Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Use a Phillips screwdriver to remove the CM2.5*3 screw on the shown cover.
    • Lift and remove the cover from the side that had the holdinging screw.
    • Lifting the plastic cover will require some pressure.
  2. Acer Aspire E1-532-2616 Hard Drive Replacement: step 2, image 1 of 1
    • Unscrew the two CM2*3-4 screws that attach the hard drive to the Laptop.
  3. Acer Aspire E1-532-2616 Hard Drive Replacement: step 3, image 1 of 2 Acer Aspire E1-532-2616 Hard Drive Replacement: step 3, image 2 of 2
    • Push the hard drive away from where the screws were (to the left, if referring to the picture).
    • The hard drive will slide to the left, allowing it to be safely removed.
One Comment
Hello! Is it possible to recover data from it? My laptop is dead and I don't know how I could recover my files.. I'm not good in computers :D thank you in advance!
Andri HaiHui - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 2,123
