Acer Aspire E1-532-2616 RAM Replacement
  1. Acer Aspire E1-532-2616 RAM Replacement, RAM: step 1, image 1 of 2 Acer Aspire E1-532-2616 RAM Replacement, RAM: step 1, image 2 of 2
    • Use a Phillips screwdriver to remove the CM2.5*3 screw on the shown cover.
    • Lift and remove the cover from the end that had the holdinging screw.
    • Lifting the plastic cover will require some pressure.
  2. Acer Aspire E1-532-2616 RAM Replacement: step 2, image 1 of 3 Acer Aspire E1-532-2616 RAM Replacement: step 2, image 2 of 3 Acer Aspire E1-532-2616 RAM Replacement: step 2, image 3 of 3
    • Push out the tabs on the other side of the RAM stick.
    • The RAM stick should raise up when the tabs are depressed.
    • Pull the RAM stick out
    • When replacing, make sure to line up the inserts.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 625
