Acer Aspire E5-571 Battery Replacement
daniel sawyer
daniel sawyer and 5 other contributors
Last updated on June 19, 2024
1 minute
Very easy
Better Introduction
Introduction
Go to step 1
Can't seem to charge your battery? It may be time to replace it. This guide will walk you through the simple steps to access and replace the battery from your Acer Aspire E5-571 laptop.
Tools
  • Spudger
    Spudger
  1. Acer Aspire E5-571 Battery Replacement, Battery: step 1, image 1 of 1
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 Battery Replacement: step 2, image 1 of 1
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
    On the E-572P the hdd and memory is accessed from the removable flap on the bottom of the laptop - do not try to take the keyboard off!
    Peter - Reply
  3. Acer Aspire E5-571 Battery Replacement: step 3, image 1 of 1
    • Pull the battery towards you to remove it from the laptop.
    A fost extrem de ușor de scos bateria Dacă toate ghidurile ar fi așa de explicite ar fi extraordinar
    Trasor - Reply
8 other people completed this guide.
daniel sawyer
2,602 Reputation
5 Guides authored
USF Tampa, Team 4-2, Meier Fall 2015 Member of USF Tampa, Team 4-2, Meier Fall 2015
USFT-MEIER-F15S4G2
3 Members
5 Guides authored
2 Comments
Uh…this makes no mention of the keyboard. Why is this titled as a keyboard repair, when it simply removes the battery?
David Greene - Reply
lets hope next time the “This guide is being worked on by hardworking students. “ the steps involve more then just removing the battery
mechanimal15 - Reply
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 48
All Time: 24,263
