Acer Aspire E5-571 CPU Fan Replacement
  1. Acer Aspire E5-571 CPU Fan Replacement, Battery: step 1, image 1 of 1
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 CPU Fan Replacement: step 2, image 1 of 1
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 CPU Fan Replacement: step 3, image 1 of 1
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571 CPU Fan Replacement, Keyboard: step 4, image 1 of 1
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer Aspire E5-571 CPU Fan Replacement: step 5, image 1 of 3 Acer Aspire E5-571 CPU Fan Replacement: step 5, image 2 of 3 Acer Aspire E5-571 CPU Fan Replacement: step 5, image 3 of 3
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips.
  6. Acer Aspire E5-571 CPU Fan Replacement: step 6, image 1 of 2 Acer Aspire E5-571 CPU Fan Replacement: step 6, image 2 of 2
    • Carefully flip up the white hinge. Detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
  7. Acer Aspire E5-571 CPU Fan Replacement, WiFi: step 7, image 1 of 1
    • Locate the WiFi card on the motherboard.
  8. Acer Aspire E5-571 CPU Fan Replacement: step 8, image 1 of 2 Acer Aspire E5-571 CPU Fan Replacement: step 8, image 2 of 2
    • Locate the two antenna cables shown.
    • Using a plastic opening tool, remove both antenna cables from the WiFi card by gently prying them up.
    • Black on left. White on right.
  9. Acer Aspire E5-571 CPU Fan Replacement: step 9, image 1 of 3 Acer Aspire E5-571 CPU Fan Replacement: step 9, image 2 of 3 Acer Aspire E5-571 CPU Fan Replacement: step 9, image 3 of 3
    • Remove this 3 mm Phillips #0 screw and the WiFi card should pop up.
    • Make sure antenna cables are removed before removing the screw.
    • Gently lift WiFi card off of the motherboard.
  10. Acer Aspire E5-571 CPU Fan Replacement, CPU Fan: step 10, image 1 of 1
    • Locate the CPU Fan in the case right above the motherboard.
  11. Acer Aspire E5-571 CPU Fan Replacement: step 11, image 1 of 1
    • Detach the power cable by carefully pulling on it, it will come off easily.
  12. Acer Aspire E5-571 CPU Fan Replacement: step 12, image 1 of 1
    • Remove both of these 6 mm Phillips #1 screws which hold the fan onto the case.
    • Now carefully lift the fan straight up and out of its place in the case.
    • The fan should easily come right out with no trouble.
4 other people completed this guide.
daniel sawyer
2,566 Reputation
5 Guides authored
USF Tampa, Team 4-2, Meier Fall 2015 Member of USF Tampa, Team 4-2, Meier Fall 2015
USFT-MEIER-F15S4G2
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 24
All Time: 4,350
