Acer Aspire E5-571-58CG CPU Fan Replacement
  1. Acer Aspire E5-571-58CG CPU Fan Replacement, Battery: step 1, image 1 of 2 Acer Aspire E5-571-58CG CPU Fan Replacement, Battery: step 1, image 2 of 2
    • Make sure the laptop is powered off.
    • Flip the laptop over and locate the battery release switch.
    • Insert the pointed end of the spudger into the battery release switch.
    • Push the battery release switch to the right.
  2. Acer Aspire E5-571-58CG CPU Fan Replacement: step 2, image 1 of 3 Acer Aspire E5-571-58CG CPU Fan Replacement: step 2, image 2 of 3 Acer Aspire E5-571-58CG CPU Fan Replacement: step 2, image 3 of 3
    • While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
  3. Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: step 3, image 1 of 3 Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: step 3, image 2 of 3 Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: step 3, image 3 of 3
    • Remove the top panel of the laptop with the plastic opening tool.
  4. Acer Aspire E5-571-58CG CPU Fan Replacement: step 4, image 1 of 2 Acer Aspire E5-571-58CG CPU Fan Replacement: step 4, image 2 of 2
    • Use a JIS #000 screw bit to remove the marked screw.
  5. Acer Aspire E5-571-58CG CPU Fan Replacement: step 5, image 1 of 2 Acer Aspire E5-571-58CG CPU Fan Replacement: step 5, image 2 of 2
    • Carefully pull the marked green chip out of the motherboard.
  6. Acer Aspire E5-571-58CG CPU Fan Replacement: step 6, image 1 of 2 Acer Aspire E5-571-58CG CPU Fan Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to unplug the wire connecting the fan to the motherboard.
  7. Acer Aspire E5-571-58CG CPU Fan Replacement: step 7, image 1 of 3 Acer Aspire E5-571-58CG CPU Fan Replacement: step 7, image 2 of 3 Acer Aspire E5-571-58CG CPU Fan Replacement: step 7, image 3 of 3
    • Use a JIS #00 screw bit to remove the marked screws around the CPU fan.
    • Carefully remove the CPU fan.
Brendan Cuthill
121 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 320
