Acer Aspire E5-571-58CG Keyboard Replacement
  1. Acer Aspire E5-571-58CG Keyboard Replacement, Battery: step 1, image 1 of 2 Acer Aspire E5-571-58CG Keyboard Replacement, Battery: step 1, image 2 of 2
    • Make sure the laptop is powered off.
    • Flip the laptop over and locate the battery release switch.
    • Insert the pointed end of the spudger into the battery release switch.
    • Push the battery release switch to the right.
  2. Acer Aspire E5-571-58CG Keyboard Replacement: step 2, image 1 of 3 Acer Aspire E5-571-58CG Keyboard Replacement: step 2, image 2 of 3 Acer Aspire E5-571-58CG Keyboard Replacement: step 2, image 3 of 3
    • While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
  3. Acer Aspire E5-571-58CG Keyboard Replacement, Keyboard: step 3, image 1 of 3 Acer Aspire E5-571-58CG Keyboard Replacement, Keyboard: step 3, image 2 of 3 Acer Aspire E5-571-58CG Keyboard Replacement, Keyboard: step 3, image 3 of 3
    • Make sure laptop is upright.
    • Pry the keyboard cover off with the plastic opening tool.
  4. Acer Aspire E5-571-58CG Keyboard Replacement: step 4, image 1 of 3 Acer Aspire E5-571-58CG Keyboard Replacement: step 4, image 2 of 3 Acer Aspire E5-571-58CG Keyboard Replacement: step 4, image 3 of 3
    • Flip the keyboard cover upside down.
    • Use the JIS #000 screw bit to remove the marked M1.4 x 2 mm screws from the back of the metal panel.
  5. Acer Aspire E5-571-58CG Keyboard Replacement: step 5, image 1 of 3 Acer Aspire E5-571-58CG Keyboard Replacement: step 5, image 2 of 3 Acer Aspire E5-571-58CG Keyboard Replacement: step 5, image 3 of 3
    • Push the metal panel forward to unlock it from plastic holders on both sides.
    • Lift the metal panel up and peel it back to expose the keyboard component.
  6. Acer Aspire E5-571-58CG Keyboard Replacement: step 6, image 1 of 3 Acer Aspire E5-571-58CG Keyboard Replacement: step 6, image 2 of 3 Acer Aspire E5-571-58CG Keyboard Replacement: step 6, image 3 of 3
    • Use the metal spudger to lift the keyboard component out of the metal panel.
Matthew Barboza
159 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 487
