Acer Aspire E5-571-58CG Power Jack Replacement
  1. Acer Aspire E5-571-58CG Power Jack Replacement, Battery: step 1, image 1 of 2 Acer Aspire E5-571-58CG Power Jack Replacement, Battery: step 1, image 2 of 2
    • Make sure the laptop is powered off.
    • Flip the laptop over and locate the battery release switch.
    • Insert the pointed end of the spudger into the battery release switch.
    • Push the battery release switch to the right.
  2. Acer Aspire E5-571-58CG Power Jack Replacement: step 2, image 1 of 3 Acer Aspire E5-571-58CG Power Jack Replacement: step 2, image 2 of 3 Acer Aspire E5-571-58CG Power Jack Replacement: step 2, image 3 of 3
    • While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
  3. Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: step 3, image 1 of 3 Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: step 3, image 2 of 3 Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: step 3, image 3 of 3
    • Remove the top panel of the laptop with the plastic opening tool.
  4. Acer Aspire E5-571-58CG Power Jack Replacement: step 4, image 1 of 2 Acer Aspire E5-571-58CG Power Jack Replacement: step 4, image 2 of 2
    • Remove the plastic safeguard from the CD drive slot.
  5. Acer Aspire E5-571-58CG Power Jack Replacement: step 5, image 1 of 3 Acer Aspire E5-571-58CG Power Jack Replacement: step 5, image 2 of 3 Acer Aspire E5-571-58CG Power Jack Replacement: step 5, image 3 of 3
    • Remove the marked screws with the JIS #00 screwdriver.
  6. Acer Aspire E5-571-58CG Power Jack Replacement: step 6, image 1 of 2 Acer Aspire E5-571-58CG Power Jack Replacement: step 6, image 2 of 2
    • Disconnect the opposite end of the power jack from the motherboard by carefully pulling the wire.
  7. Acer Aspire E5-571-58CG Power Jack Replacement: step 7, image 1 of 2 Acer Aspire E5-571-58CG Power Jack Replacement: step 7, image 2 of 2
    • Lift the bottom right side of the screen to move the metal plate covering the power jack.
  8. Acer Aspire E5-571-58CG Power Jack Replacement: step 8, image 1 of 2 Acer Aspire E5-571-58CG Power Jack Replacement: step 8, image 2 of 2
    • Carefully lift the power jack out of the laptop.
Aliana Johnson
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 1,280
