Acer Aspire E5-571-58CG Touchpad Replacement
  1. Acer Aspire E5-571-58CG Touchpad Replacement, Keyboard: step 1, image 1 of 3 Acer Aspire E5-571-58CG Touchpad Replacement, Keyboard: step 1, image 2 of 3 Acer Aspire E5-571-58CG Touchpad Replacement, Keyboard: step 1, image 3 of 3
    • Make sure laptop is upright.
    • Pry the keyboard cover off with the plastic opening tool.
  2. Acer Aspire E5-571-58CG Touchpad Replacement: step 2, image 1 of 3 Acer Aspire E5-571-58CG Touchpad Replacement: step 2, image 2 of 3 Acer Aspire E5-571-58CG Touchpad Replacement: step 2, image 3 of 3
    • Flip the keyboard cover upside down.
    • Use the JIS #000 screw bit to remove the marked M1.4 x 2 mm screws from the back of the metal panel.
  3. Acer Aspire E5-571-58CG Touchpad Replacement: step 3, image 1 of 3 Acer Aspire E5-571-58CG Touchpad Replacement: step 3, image 2 of 3 Acer Aspire E5-571-58CG Touchpad Replacement: step 3, image 3 of 3
    • Push the metal panel forward to unlock it from plastic holders on both sides.
    • Lift the metal panel up and peel it back to expose the keyboard component.
  4. Acer Aspire E5-571-58CG Touchpad Replacement: step 4, image 1 of 3 Acer Aspire E5-571-58CG Touchpad Replacement: step 4, image 2 of 3 Acer Aspire E5-571-58CG Touchpad Replacement: step 4, image 3 of 3
    • Use the metal spudger to lift the keyboard component out of the metal panel.
  5. Acer Aspire E5-571-58CG Touchpad Replacement, Touchpad: step 5, image 1 of 2 Acer Aspire E5-571-58CG Touchpad Replacement, Touchpad: step 5, image 2 of 2
    • Make sure you have removed the keyboard before attempting to remove the touchpad.
    • Use a 1 1/2 mm flathead screw bit to remove the black screw at the bottom of the panel.
  6. Acer Aspire E5-571-58CG Touchpad Replacement: step 6, image 1 of 3 Acer Aspire E5-571-58CG Touchpad Replacement: step 6, image 2 of 3 Acer Aspire E5-571-58CG Touchpad Replacement: step 6, image 3 of 3
    • Peel back the marked strips with the metal spudger.
  7. Acer Aspire E5-571-58CG Touchpad Replacement: step 7, image 1 of 3 Acer Aspire E5-571-58CG Touchpad Replacement: step 7, image 2 of 3 Acer Aspire E5-571-58CG Touchpad Replacement: step 7, image 3 of 3
    • Use a 1 1/2 mm flathead screw bit to remove the two black screws at the top of the panel.
  8. Acer Aspire E5-571-58CG Touchpad Replacement: step 8, image 1 of 2 Acer Aspire E5-571-58CG Touchpad Replacement: step 8, image 2 of 2
    • Lift the touch pad out of the metal panel with a metal spudger.
Daniel Mello
258 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 1,257
