Acer Aspire E5-571P-55TL Motherboard Replacement
  1. Acer Aspire E5-571P-55TL Motherboard Replacement, Battery: step 1, image 1 of 1
    • Make sure that laptop is turned off.
    • Turn the laptop upside down with the battery facing you.
  2. Acer Aspire E5-571P-55TL Motherboard Replacement: step 2, image 1 of 1
    • Place the Spudger into the battery lock and slide it to the left until you hear the battery unlock.
  3. Acer Aspire E5-571P-55TL Motherboard Replacement: step 3, image 1 of 2 Acer Aspire E5-571P-55TL Motherboard Replacement: step 3, image 2 of 2
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571P-55TL Motherboard Replacement, Keyboard: step 4, image 1 of 2 Acer Aspire E5-571P-55TL Motherboard Replacement, Keyboard: step 4, image 2 of 2
    • Using a Phillips #0 screwdriver, remove each of the eighteen 8 mm screws from the bottom of the laptop.
  5. Acer Aspire E5-571P-55TL Motherboard Replacement: step 5, image 1 of 3 Acer Aspire E5-571P-55TL Motherboard Replacement: step 5, image 2 of 3 Acer Aspire E5-571P-55TL Motherboard Replacement: step 5, image 3 of 3
    • Carefully place your fingers underneath the top of the keyboard just below the screen.
    • Pull upwards until you can hear the keyboard click out of place.
    • Continue around the entire laptop, carefully pulling the keyboard and palm rest assembly slightly from the frame to reveal the ribbon connectors.
    • Don't pull the keyboard off the frame yet because it's attached by ribbon connectors.
    • After the keyboard is detached, unplug each of the three ribbon cables and remove the keyboard and palm rest assembly.
  6. Acer Aspire E5-571P-55TL Motherboard Replacement, CPU Fan: step 6, image 1 of 2 Acer Aspire E5-571P-55TL Motherboard Replacement, CPU Fan: step 6, image 2 of 2
    • Before replacing the CPU fan, you'll have to remove the network card found below the fan.
    • Using a Philips #0 screwdriver, remove the two 3 mm screws from the corners of the Wi-Fi card.
    • Carefully lift the network card from it's slot, and disconnect the two coaxial cables.
  7. Acer Aspire E5-571P-55TL Motherboard Replacement: step 7, image 1 of 2 Acer Aspire E5-571P-55TL Motherboard Replacement: step 7, image 2 of 2
    • The CPU fan can be found in the upper left corner of the laptop.
    • Using a Phillips #0 screwdriver, remove the two 4.5 mm screws from the fan.
  8. Acer Aspire E5-571P-55TL Motherboard Replacement: step 8, image 1 of 2 Acer Aspire E5-571P-55TL Motherboard Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to safely remove the fan plug from the motherboard. To remove the plug, gently push left.
  9. Acer Aspire E5-571P-55TL Motherboard Replacement: step 9, image 1 of 1
    • Make sure that all fan wires are disconnected from the board.
    • Lift the curved end of the fan, and safely remove it.
  10. Acer Aspire E5-571P-55TL Motherboard Replacement, Hard Drive: step 10, image 1 of 1
    • Using a Phillips #0 screwdriver, remove the two 8 mm screws holding the hard drive carriage in place.
  11. Acer Aspire E5-571P-55TL Motherboard Replacement: step 11, image 1 of 2 Acer Aspire E5-571P-55TL Motherboard Replacement: step 11, image 2 of 2
    • Carefully unplug the ribbon cable running across the hard drive carriage and place it to the side.
    • Remove the hard drive by sliding it to your right, away from the motherboard, next pull the hard drive towards yourself and away from the laptop.
  12. Acer Aspire E5-571P-55TL Motherboard Replacement: step 12, image 1 of 1
    • Once again using a Phillips #0 screwdriver, remove the two 3 mm screws highlighted on each side of the hard drive case.
    • Open the hard drive case to replace the hard drive.
  13. Acer Aspire E5-571P-55TL Motherboard Replacement, Motherboard: step 13, image 1 of 2 Acer Aspire E5-571P-55TL Motherboard Replacement, Motherboard: step 13, image 2 of 2
    • With a Phillips #0 screwdriver, remove the two 4 mm screws from the motherboard.
  14. Acer Aspire E5-571P-55TL Motherboard Replacement: step 14, image 1 of 3 Acer Aspire E5-571P-55TL Motherboard Replacement: step 14, image 2 of 3 Acer Aspire E5-571P-55TL Motherboard Replacement: step 14, image 3 of 3
    • Carefully disconnect the speaker connection to the motherboard.
  15. Acer Aspire E5-571P-55TL Motherboard Replacement: step 15, image 1 of 3 Acer Aspire E5-571P-55TL Motherboard Replacement: step 15, image 2 of 3 Acer Aspire E5-571P-55TL Motherboard Replacement: step 15, image 3 of 3
    • The last connection to the motherboard is the screen. Gently disconnect the cable from the motherboard.
  16. Acer Aspire E5-571P-55TL Motherboard Replacement: step 16, image 1 of 1
    • Lift the motherboard up from the top right corner, and then pull it right to release it from the case.
Max Piekos
459 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 368
