Acer Aspire ES1-512-C80E Disk Drive Replacement
  1. Acer Aspire ES1-512-C80E Disk Drive Replacement, Back Cover: step 1, image 1 of 1
    • Place the device upside down on a flat surface.
    • Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
  2. Acer Aspire ES1-512-C80E Disk Drive Replacement: step 2, image 1 of 3 Acer Aspire ES1-512-C80E Disk Drive Replacement: step 2, image 2 of 3 Acer Aspire ES1-512-C80E Disk Drive Replacement: step 2, image 3 of 3
    • Pry around the edges with a spudger to remove the back cover.
    • The two hinges on the back require additional force to be popped open.
  3. Acer Aspire ES1-512-C80E Disk Drive Replacement, Keyboard: step 3, image 1 of 3 Acer Aspire ES1-512-C80E Disk Drive Replacement, Keyboard: step 3, image 2 of 3 Acer Aspire ES1-512-C80E Disk Drive Replacement, Keyboard: step 3, image 3 of 3
    • The keyboard is the silver piece located by itself on the upper half of the laptop.
    • Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
    • Using a spudger, go around the edges and pry off the keyboard.
    • All black clips will have to be removed before the keyboard can be removed.
  4. Acer Aspire ES1-512-C80E Disk Drive Replacement: step 4, image 1 of 3 Acer Aspire ES1-512-C80E Disk Drive Replacement: step 4, image 2 of 3 Acer Aspire ES1-512-C80E Disk Drive Replacement: step 4, image 3 of 3
    • Remove the ribbon cable connection from the keyboard.
    • Peel back the two pieces of tape to separate the keyboard.
    • Remove the keyboard from under the plastic covering.
    • Remove the silver plate back cover of the keyboard from the bottom base.
  5. Acer Aspire ES1-512-C80E Disk Drive Replacement: step 5, image 1 of 2 Acer Aspire ES1-512-C80E Disk Drive Replacement: step 5, image 2 of 2
    • Remove the large silver plate from the keyboard.
    • You can not remove the silver backing with the attached wire from the back of the keyboard.
  6. Acer Aspire ES1-512-C80E Disk Drive Replacement: step 6, image 1 of 1
    • The keyboard is removed and ready to be replaced.
  7. Acer Aspire ES1-512-C80E Disk Drive Replacement, Disk Drive: step 7, image 1 of 3 Acer Aspire ES1-512-C80E Disk Drive Replacement, Disk Drive: step 7, image 2 of 3 Acer Aspire ES1-512-C80E Disk Drive Replacement, Disk Drive: step 7, image 3 of 3
    • Push the disk drive out of the side slot.
To reassemble your device, follow the steps in reverse order.
Peter Bulman
231 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 458
