Acer Aspire ES1-711-P1UV Battery Replacement
  1. Acer Aspire ES1-711-P1UV Battery Replacement, Battery: step 1, image 1 of 1
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Acer Aspire ES1-711-P1UV Battery Replacement: step 2, image 1 of 1
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. Acer Aspire ES1-711-P1UV Battery Replacement: step 3, image 1 of 1
    • Remove the two 5 mm screws located on either side of the battery.
  4. Acer Aspire ES1-711-P1UV Battery Replacement: step 4, image 1 of 1
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
4 other people completed this guide.
Lindsay O'Shea
414 Reputation
3 Guides authored
2 Comments
Excellent instructions, Thxz.
jmarquez_cruz - Reply
Wuen i reassemble my laptop doesnt power on…
mk Bane - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 31
All Time: 4,159
