Acer Aspire M5-583P-9688 Hard Drive Replacement
  1. Acer Aspire M5-583P-9688 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Remove the 18 marked screws (2.12 mm) using a Phillips #1 head screwdriver.
  2. Acer Aspire M5-583P-9688 Hard Drive Replacement: step 2, image 1 of 2 Acer Aspire M5-583P-9688 Hard Drive Replacement: step 2, image 2 of 2
    • Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
  3. Acer Aspire M5-583P-9688 Hard Drive Replacement: step 3, image 1 of 2 Acer Aspire M5-583P-9688 Hard Drive Replacement: step 3, image 2 of 2
    • This particular laptop does not have a hard drive. The red rectangle is where your hard drive will be.
    • To remove the hard drive, carefully take it out of the brackets holding it in place. Once you have it out of the brackets, remove the connector from the hard drive.
3 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 1,602
