Acer Aspire One 532h-2806 Keyboard Replacement
  1. Acer Aspire One 532h-2806 Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Make sure the laptop is turned off and the battery is removed.
    • Above the top row of the keys, locate three plastic latches.
  2. Acer Aspire One 532h-2806 Keyboard Replacement: step 2, image 1 of 1
    • Use the medal spudger to press each tab. The keyboard should release.
    • Slide the spudger, so that the tabs do not reset after pressing each one.
  3. Acer Aspire One 532h-2806 Keyboard Replacement: step 3, image 1 of 1
    • Gently lift the keyboard up.
    • The keyboard ribbon cable is still attached to the motherboard.
  4. Acer Aspire One 532h-2806 Keyboard Replacement: step 4, image 1 of 1
    • Carefully unplug the connector sticker on the back of the keyboard.
    • Be gentle, do not force it out.
  5. Acer Aspire One 532h-2806 Keyboard Replacement: step 5, image 1 of 1
    • Remove the keyboard.
Julie Paula
527 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 380
