Acer Aspire One 532h-2806 RAM Replacement
  1. Acer Aspire One 532h-2806 RAM Replacement, RAM: step 1, image 1 of 1
    • Turn off the computer and remove the battery before removing parts.
    • Use a Phillips #0 screwdriver to remove the 6mm screw from the back of the computer.
  2. Acer Aspire One 532h-2806 RAM Replacement: step 2, image 1 of 2 Acer Aspire One 532h-2806 RAM Replacement: step 2, image 2 of 2
    • Use an opening tool to remove the plastic plate covering the RAM, using the notch on the bottom right side.
    • Remove the plate.
  3. Acer Aspire One 532h-2806 RAM Replacement: step 3, image 1 of 2 Acer Aspire One 532h-2806 RAM Replacement: step 3, image 2 of 2
    • At the same time, press the latches on the sides of the RAM card to remove it.
    • The RAM should pop up.
  4. Acer Aspire One 532h-2806 RAM Replacement: step 4, image 1 of 1
    • Remove the RAM card.
3 other people completed this guide.
Julie Paula
527 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 594
