Acer Aspire One 532h-2806 Screen Replacement
  1. Acer Aspire One 532h-2806 Screen Replacement, Screen: step 1, image 1 of 2 Acer Aspire One 532h-2806 Screen Replacement, Screen: step 1, image 2 of 2
    • Turn the device off before beginning any replacements.
    • Locate the two circular black stickers at the bottom corners of the laptop screen.
    • Remove the stickers.
    • Two 6mm Phillips Screws should now be visible.
  2. Acer Aspire One 532h-2806 Screen Replacement: step 2, image 1 of 2 Acer Aspire One 532h-2806 Screen Replacement: step 2, image 2 of 2
    • Use a Phillips #0 Screwdriver to remove the two 6mm screws from the screen.
  3. Acer Aspire One 532h-2806 Screen Replacement: step 3, image 1 of 2 Acer Aspire One 532h-2806 Screen Replacement: step 3, image 2 of 2
    • Using the opener tool, remove the plastic cover, surrounding the screen.
    • It is normal to hear clicking sounds as the plastic cover is removed.
  4. Acer Aspire One 532h-2806 Screen Replacement: step 4, image 1 of 3 Acer Aspire One 532h-2806 Screen Replacement: step 4, image 2 of 3 Acer Aspire One 532h-2806 Screen Replacement: step 4, image 3 of 3
    • Remove the four 6mm Phillips screws surrounding the screen.
    • These are holding the screen in place. After the screws are removed, the screen should remove itself from the plastic outer cover.
  5. Acer Aspire One 532h-2806 Screen Replacement: step 5, image 1 of 1
    • Peel back the fuss cable from the outer laptop plastic cover.
    • Be careful, not to yank or rip the cable, it should gently peel back.
  6. Acer Aspire One 532h-2806 Screen Replacement: step 6, image 1 of 1
    • Locate the ZIF (zero insertion force) Cable.
    • Peel back any tape if necessary
    • Carefully unplug it.
    • Do not pull hard, it should remove itself easily.
  7. Acer Aspire One 532h-2806 Screen Replacement: step 7, image 1 of 2 Acer Aspire One 532h-2806 Screen Replacement: step 7, image 2 of 2
    • Remove the two 6mm screws on each side of the screen with a Phillips #0 screwdriver.
  8. Acer Aspire One 532h-2806 Screen Replacement: step 8, image 1 of 3 Acer Aspire One 532h-2806 Screen Replacement: step 8, image 2 of 3 Acer Aspire One 532h-2806 Screen Replacement: step 8, image 3 of 3
    • Remove the screen.
2 other people completed this guide.
Julie Paula
527 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 316
