Acer Aspire One 722 Battery Replacement
  1. Acer Aspire One 722 Battery Replacement, Battery: step 1, image 1 of 1
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 Battery Replacement: step 2, image 1 of 1
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 Battery Replacement: step 3, image 1 of 1
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 Battery Replacement: step 4, image 1 of 2 Acer Aspire One 722 Battery Replacement: step 4, image 2 of 2
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 Battery Replacement: step 5, image 1 of 1
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
12 other people completed this guide.
Christian Barboza
818 Reputation
5 Guides authored
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G6
3 Members
10 Guides authored
4 Comments
First rate easy to understand completed in less than a minute.many thanks
Alan Fowler - Reply
I find myself computer savvy. These steps jarred my memory. They were perfect.
scolan910 - Reply
Thank you, you are a hero of 2021.
Athirah siagian - Reply
Thank you. Simple, yes, but a little encouragement always helps.
Wade Stanfill - Reply
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 31
All Time: 12,425
