Acer Aspire One 722 Keyboard Keys and Battery Replacement
Christian Barboza
Christian Barboza and 7 other contributors
Last updated on August 12, 2021
15 - 20 minutes
Moderate
Introduction
Go to step 1
This guide will show you how to replace your Acer Aspire One 772 keyboard keys and battery, if necessary. Following the steps below will allow you to replace any damaged or broken keys on your netbook.
Before you begin:
  • Please note that a battery replacement is not required in order to replace your keyboard keys.
  • You will need to purchase new keys if the keys OR pivoting pieces beneath the key are replacing are broken.
  • Steps 2-5 will help you replace your battery and steps 6-10 will help you replace the keys.
  • Please remember to completely shut down your netbook before any of the following replacements.
Parts
Tools
  • Spudger
    Spudger
Show more…
iFixit earns commission when you buy through these links.
  1. Acer Aspire One 722 Keyboard Keys and Battery Replacement, Battery: step 1, image 1 of 1
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 Keyboard Keys and Battery Replacement: step 2, image 1 of 1
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 Keyboard Keys and Battery Replacement: step 3, image 1 of 1
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 Keyboard Keys and Battery Replacement: step 4, image 1 of 2 Acer Aspire One 722 Keyboard Keys and Battery Replacement: step 4, image 2 of 2
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 Keyboard Keys and Battery Replacement: step 5, image 1 of 1
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
  6. Acer Aspire One 722 Keyboard Keys and Battery Replacement, Keyboard Keys and Battery: step 6, image 1 of 1
    • Use the flat end of a spudger to pry off the keyboard key.
    • If the key is broken, just remove the broken key and press a new key down over the empty key area. If you need to repair the key, follow the steps below.
  7. Acer Aspire One 722 Keyboard Keys and Battery Replacement: step 7, image 1 of 2 Acer Aspire One 722 Keyboard Keys and Battery Replacement: step 7, image 2 of 2
    • Use a spudger to pry the upper portion on both sides of the mechanism until it pops off from the key socket.
  8. Acer Aspire One 722 Keyboard Keys and Battery Replacement: step 8, image 1 of 3 Acer Aspire One 722 Keyboard Keys and Battery Replacement: step 8, image 2 of 3 Acer Aspire One 722 Keyboard Keys and Battery Replacement: step 8, image 3 of 3
    • Take both pivoting pieces of the mechanism and put them together.
    • The smaller piece fits through the inner part of the larger piece and lays in the groove of the larger piece.
    • Once assembled, it should be entirely flat.
  9. Acer Aspire One 722 Keyboard Keys and Battery Replacement: step 9, image 1 of 1
    • Position the pivoting smaller piece of the key mechanism in the lower hooks of the key socket.
    • Slide your finger across the upper portion of the key mechanism so that it locks in place with the upper hooks of the key socket.
  10. Acer Aspire One 722 Keyboard Keys and Battery Replacement: step 10, image 1 of 1
    • Place the key on top of the empty key space and press it down firmly until the key locks in place.
Christian Barboza
818 Reputation
5 Guides authored
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G6
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 18
All Time: 4,443
