Acer Aspire One 722 RAM Replacement
  1. Acer Aspire One 722 RAM Replacement, Battery: step 1, image 1 of 1
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 RAM Replacement: step 2, image 1 of 1
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 RAM Replacement: step 3, image 1 of 1
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 RAM Replacement: step 4, image 1 of 2 Acer Aspire One 722 RAM Replacement: step 4, image 2 of 2
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 RAM Replacement: step 5, image 1 of 1
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
  6. Acer Aspire One 722 RAM Replacement, RAM: step 6, image 1 of 1
    • Remove the screw at the bottom of the laptop.
  7. Acer Aspire One 722 RAM Replacement: step 7, image 1 of 1
    • Take the plastic backing plate off.
  8. Acer Aspire One 722 RAM Replacement: step 8, image 1 of 1
    • Unclip the two metal braces that hold the RAM in place by pushing the metal clips outwards away from the RAM itself.
    • The RAM should pop up.
  9. Acer Aspire One 722 RAM Replacement: step 9, image 1 of 1
    • Grab the RAM and remove slowly.
  10. Acer Aspire One 722 RAM Replacement: step 10, image 1 of 1
    • Take the replacement RAM stick and line up the the grooves on the RAM to the grooves on the netbook so that they will fit in flush.
  11. Acer Aspire One 722 RAM Replacement: step 11, image 1 of 1
    • Press down on the RAM stick and the metal clips will lock in to place.
3 other people completed this guide.
Christian Barboza
824 Reputation
5 Guides authored
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G6
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 44
All Time: 2,453
