Acer Aspire One 722 Screen Replacement
  1. Acer Aspire One 722 Screen Replacement, Battery: step 1, image 1 of 1
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 Screen Replacement: step 2, image 1 of 1
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 Screen Replacement: step 3, image 1 of 1
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 Screen Replacement: step 4, image 1 of 2 Acer Aspire One 722 Screen Replacement: step 4, image 2 of 2
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 Screen Replacement: step 5, image 1 of 1
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
  6. Acer Aspire One 722 Screen Replacement, Screen: step 6, image 1 of 2 Acer Aspire One 722 Screen Replacement, Screen: step 6, image 2 of 2
    • Remove the black rubber clips from the bottom right and left of the netbook screen.
  7. Acer Aspire One 722 Screen Replacement: step 7, image 1 of 2 Acer Aspire One 722 Screen Replacement: step 7, image 2 of 2
    • Remove the screws under the black caps.
  8. Acer Aspire One 722 Screen Replacement: step 8, image 1 of 3 Acer Aspire One 722 Screen Replacement: step 8, image 2 of 3 Acer Aspire One 722 Screen Replacement: step 8, image 3 of 3
    • Slowly separate the screen casing from the screen.
    • Potential for device damage: Be careful when detaching the screen casing from the screen. If not done slowly, it can break.
  9. Acer Aspire One 722 Screen Replacement: step 9, image 1 of 3 Acer Aspire One 722 Screen Replacement: step 9, image 2 of 3 Acer Aspire One 722 Screen Replacement: step 9, image 3 of 3
    • Remove the screws located on the four corners of the screen.
  10. Acer Aspire One 722 Screen Replacement: step 10, image 1 of 3 Acer Aspire One 722 Screen Replacement: step 10, image 2 of 3 Acer Aspire One 722 Screen Replacement: step 10, image 3 of 3
    • Remove the two bottom screws.
    • Taking out these screws will allow you to remove the screen from its attachment.
  11. Acer Aspire One 722 Screen Replacement: step 11, image 1 of 3 Acer Aspire One 722 Screen Replacement: step 11, image 2 of 3 Acer Aspire One 722 Screen Replacement: step 11, image 3 of 3
    • On the bottom left of the screen there is a cord attached. Remove the tape that is attached to the screen.
  12. Acer Aspire One 722 Screen Replacement: step 12, image 1 of 3 Acer Aspire One 722 Screen Replacement: step 12, image 2 of 3 Acer Aspire One 722 Screen Replacement: step 12, image 3 of 3
    • On the green board, remove the two screws.
    • Remove the board.
4 other people completed this guide.
Christian Barboza
818 Reputation
5 Guides authored
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G6
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 3,322
