Acer Aspire One 725-0845 RAM Replacement
  1. Acer Aspire One 725-0845 RAM Replacement, Battery: step 1, image 1 of 1
    • Ensure the device is powered off by holding down the power button on the top left-hand side.
    • On a flat, level surface, flip the device over so that the back-plate is accessible.
  2. Acer Aspire One 725-0845 RAM Replacement: step 2, image 1 of 3 Acer Aspire One 725-0845 RAM Replacement: step 2, image 2 of 3 Acer Aspire One 725-0845 RAM Replacement: step 2, image 3 of 3
    • Using a spudger or any fine-pointed tool, push the release slide away from the center of the device.
    • Simultaneously pull the battery out and away from the device.
  3. Acer Aspire One 725-0845 RAM Replacement, Back Plate: step 3, image 1 of 3 Acer Aspire One 725-0845 RAM Replacement, Back Plate: step 3, image 2 of 3 Acer Aspire One 725-0845 RAM Replacement, Back Plate: step 3, image 3 of 3
    • Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
    • Using your hands, slide the back-plate away from the center of the device and remove.
  4. Acer Aspire One 725-0845 RAM Replacement, RAM: step 4, image 1 of 3 Acer Aspire One 725-0845 RAM Replacement, RAM: step 4, image 2 of 3 Acer Aspire One 725-0845 RAM Replacement, RAM: step 4, image 3 of 3
    • Using two fingers, push the clamps away from the RAM chip, releasing it from the motherboard.
    • Carefully remove the RAM chip by pulling it out and away from the center of the device.
2 other people completed this guide.
John Allen
134 Reputation
1 Guide authored
USF Tampa, Team 8-3, Eyestone Spring 2017 Member of USF Tampa, Team 8-3, Eyestone Spring 2017
USFT-EYESTONE-S17S8G3
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 13
All Time: 531
