Introduction
This guide is simple to follow. The Internal Wireless Card can easily be removed and installed within minutes.
Flip device over so that the battery is farthest from you.
Identify the switch on the upper left corner and push it left to be in "unlocked" position.
Close and flip the device over so you can have a good view of all the screws.
Locate and remove the three 3.9mm screws where the battery was removed from.
Locate and and remove the two 5.8mm screws located underneath the bumpers.
Locate and remove the three 5.8mm remaining screws at the top of the device.
