Acer Aspire One A150-1570 Keyboard Replacement
  1. Acer Aspire One A150-1570 Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Flip device over so that the battery is farthest from you.
    • Identify the switch on the upper left corner and push it left to be in "unlocked" position.
  2. Acer Aspire One A150-1570 Keyboard Replacement: step 2, image 1 of 2 Acer Aspire One A150-1570 Keyboard Replacement: step 2, image 2 of 2
    • Identify the latch on the upper right hand corner. Drag and hold the latch to the right.
    • Pull the battery out.
  3. Acer Aspire One A150-1570 Keyboard Replacement: step 3, image 1 of 2 Acer Aspire One A150-1570 Keyboard Replacement: step 3, image 2 of 2
    • Now flip device back over to show the keyboard.
    • Locate the three tabs at the top of the keyboard.
  4. Acer Aspire One A150-1570 Keyboard Replacement: step 4, image 1 of 3 Acer Aspire One A150-1570 Keyboard Replacement: step 4, image 2 of 3 Acer Aspire One A150-1570 Keyboard Replacement: step 4, image 3 of 3
    • Start on the top-right and use the spudger to push off the tab from the keyboard.
    • Move to the middle tab while still holding the right side up so the tab doesn't fall back into place.
    • Continue to hold up keyboard while disconnecting the last tab.
    • DO NOT lift keyboard yet. This will be addressed in the next step.
  5. Acer Aspire One A150-1570 Keyboard Replacement: step 5, image 1 of 3 Acer Aspire One A150-1570 Keyboard Replacement: step 5, image 2 of 3 Acer Aspire One A150-1570 Keyboard Replacement: step 5, image 3 of 3
    • Here you can see that the keyboard is still attached to the device.
    • Use the Spudger to lift the ZIF (Zero Insertion Force) to release the keyboard ribbon.
    • Once tab is lifted, the keyboard ribbon should come right out.
2 other people completed this guide.
Blue
124 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 13
All Time: 428
