Acer Aspire One Cloudbook 14 AO1-431-C8G8 USB Port Replacement
  1. Acer Aspire One Cloudbook 14 AO1-431-C8G8 USB Port Replacement, Back Panel: step 1, image 1 of 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 USB Port Replacement, Back Panel: step 1, image 2 of 2
    • Remove the ten 7mm Phillips #0 screws from the bottom.
  2. Acer Aspire One Cloudbook 14 AO1-431-C8G8 USB Port Replacement: step 2, image 1 of 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 USB Port Replacement: step 2, image 2 of 2
    • Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release.
  3. Acer Aspire One Cloudbook 14 AO1-431-C8G8 USB Port Replacement, USB Port: step 3, image 1 of 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 USB Port Replacement, USB Port: step 3, image 2 of 2
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF socket.
    • Remove the ribbon cable from the socket.
  4. Acer Aspire One Cloudbook 14 AO1-431-C8G8 USB Port Replacement: step 4, image 1 of 2 Acer Aspire One Cloudbook 14 AO1-431-C8G8 USB Port Replacement: step 4, image 2 of 2
    • Remove the 5mm Phillips #0 screw from the USB port.
    • Remove the USB port from the device.
Joseph
685 Reputation
6 Guides authored
USF Tampa, Team S20-G1, Passmore Spring 2018 Member of USF Tampa, Team S20-G1, Passmore Spring 2018
USFT-PASSMORE-S18S20G1
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 525
