Acer Aspire One D255E Keyboard Replacement
  1. Acer Aspire One D255E Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Start by removing the battery found on the back of the device.
    • The battery must be removed in order to ensure the device does not have power! Make sure you do not skip this step!
  2. Acer Aspire One D255E Keyboard Replacement: step 2, image 1 of 2 Acer Aspire One D255E Keyboard Replacement: step 2, image 2 of 2
    • Using plastic opening tools press down the 6 clips located around the keyboard.
  3. Acer Aspire One D255E Keyboard Replacement: step 3, image 1 of 3 Acer Aspire One D255E Keyboard Replacement: step 3, image 2 of 3 Acer Aspire One D255E Keyboard Replacement: step 3, image 3 of 3
    • Using a plastic opening tool or spudger move the keyboard out of position.
    • There is a thin cable on the backside of the keyboard. Make sure when you move the keyboard out of position you do so slowly to prevent damage to this cable.
    • If you use a spudger it is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  4. Acer Aspire One D255E Keyboard Replacement: step 4, image 1 of 1
    • Using a spudger gently push the tab on the port forward then pull out the cable.
    • Be careful to do so as gently as possible. You do not want to damage the port.
3 other people completed this guide.
Brian
1,248 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 2,384
