Acer Aspire One D255E Screen Replacement
  1. Acer Aspire One D255E Screen Replacement, Screen: step 1, image 1 of 2 Acer Aspire One D255E Screen Replacement, Screen: step 1, image 2 of 2
    • Using a spudger remove the two screw covers on the front of the computer.
  2. Acer Aspire One D255E Screen Replacement: step 2, image 1 of 2 Acer Aspire One D255E Screen Replacement: step 2, image 2 of 2
    • Remove the two 1.2 mm Phillips #1 screws that were located under the screw covers.
  3. Acer Aspire One D255E Screen Replacement: step 3, image 1 of 1
    • Using a spudger for assistance remove the front panel of the screen.
    • It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  4. Acer Aspire One D255E Screen Replacement: step 4, image 1 of 3 Acer Aspire One D255E Screen Replacement: step 4, image 2 of 3 Acer Aspire One D255E Screen Replacement: step 4, image 3 of 3
    • Remove the eight 1.2 mm Phillips #1 screws holding on the screen.
    • There are wires connected to the screen unit. Make sure you do not attempt to pull off the screen just yet!
  5. Acer Aspire One D255E Screen Replacement: step 5, image 1 of 1
    • Carefully remove the display ribbon cable from the connector.
3 other people completed this guide.
Brian
1,248 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 27
All Time: 2,161
