Acer Aspire One D257 opening the hatch
  1. Acer Aspire One D257 opening the hatch, Battery: step 1, image 1 of 1
    • Put the netbook, so the back side is upwards.
  2. Acer Aspire One D257 opening the hatch: step 2, image 1 of 1
    • Push the right lock to the right so the red filed is visible on the left.
  3. Acer Aspire One D257 opening the hatch: step 3, image 1 of 1
    • Now move the left lock which is spring loaded to the leftand keep it there. Then with the other hand remove the battery by pulling down.
    • When reassembeling the new battery push it up into the netbook and do lock the right by moving it to the left so the red field disappears.
  4. Acer Aspire One D257 opening the hatch, Keyboard: step 4, image 1 of 2 Acer Aspire One D257 opening the hatch, Keyboard: step 4, image 2 of 2
    • Open the lid othe the netbook. Use the Jimmy from the upper left corner of the keyboard. Put it between the keyboard and th casing and move it to the right. It might help to use a metal spudger to push in the pins holding the keyboard in place.
    • Then move down along the sides where there is one pin on each side. After that twist the keyboard towards you.
  5. Acer Aspire One D257 opening the hatch: step 5, image 1 of 1
    • Now open the brown connector so the flat cable is loose. Then you can remove the keyboard.
  6. Acer Aspire One D257 opening the hatch, Acer Aspire One D257 opening the hatch: step 6, image 1 of 1
    • Remove the 5 screws marked with "Door".
  7. Acer Aspire One D257 opening the hatch: step 7, image 1 of 2 Acer Aspire One D257 opening the hatch: step 7, image 2 of 2
    • Use a spudger or flat screwdriver to push down the hatch where it is marked "Door release".
    • Now you can carfully remove the hatch.
    • When reassembling the hatch look that the noses are aimed at the appropriate holes in the case, then you can press down the rest of the hatch onto the netbook.
6 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Claes
3,400 Reputation
6 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,516 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 23
All Time: 2,227
