Acer Aspire R R5-471T-51UN Keyboard Replacement
  1. Acer Aspire R R5-471T-51UN Keyboard Replacement, Battery: step 1, image 1 of 3 Acer Aspire R R5-471T-51UN Keyboard Replacement, Battery: step 1, image 2 of 3 Acer Aspire R R5-471T-51UN Keyboard Replacement, Battery: step 1, image 3 of 3
    • Flip your laptop over so the bottom is facing you.
    • Remove the twelve 5 mm screws with a Phillips #0 screwdriver.
  2. Acer Aspire R R5-471T-51UN Keyboard Replacement: step 2, image 1 of 3 Acer Aspire R R5-471T-51UN Keyboard Replacement: step 2, image 2 of 3 Acer Aspire R R5-471T-51UN Keyboard Replacement: step 2, image 3 of 3
    • Insert the Jimmy between the back cover of the laptop and the base of the laptop and then slowly use the Jimmy to pry off the back cover of the laptop.
  3. Acer Aspire R R5-471T-51UN Keyboard Replacement: step 3, image 1 of 2 Acer Aspire R R5-471T-51UN Keyboard Replacement: step 3, image 2 of 2
    • Use your Phillips #0 screwdriver to remove the two 3mm screws on the battery.
  4. Acer Aspire R R5-471T-51UN Keyboard Replacement: step 4, image 1 of 3 Acer Aspire R R5-471T-51UN Keyboard Replacement: step 4, image 2 of 3 Acer Aspire R R5-471T-51UN Keyboard Replacement: step 4, image 3 of 3
    • Gently and cautiously pinch the white ends of the battery connector cable and slowly pull it from the motherboard.
  5. Acer Aspire R R5-471T-51UN Keyboard Replacement: step 5, image 1 of 2 Acer Aspire R R5-471T-51UN Keyboard Replacement: step 5, image 2 of 2
    • Gently lift the battery out of the laptop.
    • Be cautious with the lithium ion battery as you remove it.
  6. Acer Aspire R R5-471T-51UN Keyboard Replacement, Keyboard: step 6, image 1 of 3 Acer Aspire R R5-471T-51UN Keyboard Replacement, Keyboard: step 6, image 2 of 3 Acer Aspire R R5-471T-51UN Keyboard Replacement, Keyboard: step 6, image 3 of 3
    • Use the spudger to flip up the locking tabs on each of the four ZIF cable connectors.
    • Remove each of the ribbon cables from their connectors.
  7. Acer Aspire R R5-471T-51UN Keyboard Replacement: step 7, image 1 of 3 Acer Aspire R R5-471T-51UN Keyboard Replacement: step 7, image 2 of 3 Acer Aspire R R5-471T-51UN Keyboard Replacement: step 7, image 3 of 3
    • Using the Phillips #0 screwdriver, remove the eight 3 mm screws holding in the motherboard and the three 3 mm screws holding down the fan.
  8. Acer Aspire R R5-471T-51UN Keyboard Replacement: step 8, image 1 of 3 Acer Aspire R R5-471T-51UN Keyboard Replacement: step 8, image 2 of 3 Acer Aspire R R5-471T-51UN Keyboard Replacement: step 8, image 3 of 3
    • Remove the motherboard and the fan by gently pulling them out of the assembly.
    • Using the Phillips #0 screwdriver, remove the three 3 mm screws holding down the daughterboard and gently pull it up and out of the assembly.
  9. Acer Aspire R R5-471T-51UN Keyboard Replacement: step 9, image 1 of 3 Acer Aspire R R5-471T-51UN Keyboard Replacement: step 9, image 2 of 3 Acer Aspire R R5-471T-51UN Keyboard Replacement: step 9, image 3 of 3
    • Using the Phillips #0 screwdriver, remove the eight 5 mm screws from the display brackets on either side.
  10. Acer Aspire R R5-471T-51UN Keyboard Replacement: step 10, image 1 of 2 Acer Aspire R R5-471T-51UN Keyboard Replacement: step 10, image 2 of 2
    • Remove the keyboard assembly by gently pulling it up.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 512
