Acer Aspire R5-471T-52EE Speakers Replacement
  1. Acer Aspire R5-471T-52EE Speakers Replacement, Back Cover: step 1, image 1 of 2 Acer Aspire R5-471T-52EE Speakers Replacement, Back Cover: step 1, image 2 of 2
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Speakers Replacement: step 2, image 1 of 1
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
  3. Acer Aspire R5-471T-52EE Speakers Replacement, Battery: step 3, image 1 of 1
    • Using your fingers, gently disconnect the battery plug from the motherboard.
    • Remove the two screws using a Phillips #00 screwdriver.
    • Remove the battery from the device.
  4. Acer Aspire R5-471T-52EE Speakers Replacement, Speakers: step 4, image 1 of 2 Acer Aspire R5-471T-52EE Speakers Replacement, Speakers: step 4, image 2 of 2
    • Gently peel off all of the black take that sticks down the speaker cables.
    • Disconnect the two ribbon cables to allow the speaker cable to be removed from underneath.
    • Unplug the speaker cable from the motherboard.
    • Using a spudger, gently remove the speakers from the device.
One Comment
I want to replace my laptop speakers but I am not getting them from anywhere, please send a purchase link also if you have the same speakers. email : prdp9101.com@gmail.com
pradeep singh - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 281
