Acer Aspire R5-571T-59DC Battery Replacement
  1. Acer Aspire R5-571T-59DC Battery Replacement, Back Cover Panel: step 1, image 1 of 2 Acer Aspire R5-571T-59DC Battery Replacement, Back Cover Panel: step 1, image 2 of 2
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
  2. Acer Aspire R5-571T-59DC Battery Replacement, Battery: step 2, image 1 of 3 Acer Aspire R5-571T-59DC Battery Replacement, Battery: step 2, image 2 of 3 Acer Aspire R5-571T-59DC Battery Replacement, Battery: step 2, image 3 of 3
    • Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
    • Lift the battery out of the case.
Kelly Johnston
600 Reputation
4 Guides authored
USF Tampa, Team S20-G2, Passmore Spring 2018 Member of USF Tampa, Team S20-G2, Passmore Spring 2018
USFT-PASSMORE-S18S20G2
3 Members
7 Guides authored
One Comment
This seems to be the correct battery for the replacement, judging by the above photos, the AC14B3K
Acer AC14B3K, AC14B8J, and AC14B8K Laptop Battery
I plan to try this repair myself soon.
Sean Anderson - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 5,120
