Acer Aspire R7 RAM Replacement
  1. Acer Aspire R7 RAM Replacement, Cover: step 1, image 1 of 1
    • Shut down the laptop and disconnect the power cord.
    • Failing to disconnect or shut down the laptop could result in damage to the laptop or a shock hazard.
    • Turn the laptop over.
  2. Acer Aspire R7 RAM Replacement: step 2, image 1 of 3 Acer Aspire R7 RAM Replacement: step 2, image 2 of 3 Acer Aspire R7 RAM Replacement: step 2, image 3 of 3
    • Remove six 6mm T7 screws.
    • Remove four 4mm T7 screws.
    • Remove two 10mm T7 screws
    • Use the blue plastic opening tool to carefully remove both rubber pads which cover the four remaining screws.
    • Remove the remaining two10mm T7 screws.
  3. Acer Aspire R7 RAM Replacement: step 3, image 1 of 1
    • Carefully lift the cover upwards.
    • If the cover seems stuck, use a spudger tool to pry the sides.
  4. Acer Aspire R7 RAM Replacement, RAM: step 4, image 1 of 1
    • Push the retaining clips away from the RAM module, allowing the spring loaded hinge to pop up.
  5. Acer Aspire R7 RAM Replacement: step 5, image 1 of 1
    • Carefully pull the RAM module away from the motherboard.
Andrew Rodiek
601 Reputation
4 Guides authored
USF Tampa, Team 3-4, Hickman Winter 2015 Member of USF Tampa, Team 3-4, Hickman Winter 2015
USFT-HICKMAN-W15S3G4
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 48
All Time: 2,237
