Acer Aspire R7-572-6423 Hard Drive Replacement
  1. Acer Aspire R7-572-6423 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Turn off the laptop and disconnect the power adapter before attempting this guide. Failure to do so can result in a shock hazard.
  2. Acer Aspire R7-572-6423 Hard Drive Replacement: step 2, image 1 of 3 Acer Aspire R7-572-6423 Hard Drive Replacement: step 2, image 2 of 3 Acer Aspire R7-572-6423 Hard Drive Replacement: step 2, image 3 of 3
    • Remove the top and middle grips that conceal 3 additional screws.
    • Remove the 5 6mm T9 screws.
    • Remove the 8 10mm T9 screws.
  3. Acer Aspire R7-572-6423 Hard Drive Replacement: step 3, image 1 of 1
    • Remove the back cover.
  4. Acer Aspire R7-572-6423 Hard Drive Replacement: step 4, image 1 of 3 Acer Aspire R7-572-6423 Hard Drive Replacement: step 4, image 2 of 3 Acer Aspire R7-572-6423 Hard Drive Replacement: step 4, image 3 of 3
    • Unscrew the four 4mm PH0 screws holding the hard drive in place.
  5. Acer Aspire R7-572-6423 Hard Drive Replacement: step 5, image 1 of 1
    • Tilt the hard drive up and pull it away and out of its base.
    • Do not use too much force on the hard drive or tilt it so much that the base is broken.
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 18
All Time: 1,352
