Acer Aspire S3 MS2346 Battery Replacement
  1. Acer Aspire S3 MS2346 Battery Replacement, Back Cover: step 1, image 1 of 3 Acer Aspire S3 MS2346 Battery Replacement, Back Cover: step 1, image 2 of 3 Acer Aspire S3 MS2346 Battery Replacement, Back Cover: step 1, image 3 of 3
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Battery Replacement, Speakers: step 2, image 1 of 2 Acer Aspire S3 MS2346 Battery Replacement, Speakers: step 2, image 2 of 2
    • Unscrew the 4 1mm PH00 screws attaching the speakers to the frame.
  3. Acer Aspire S3 MS2346 Battery Replacement: step 3, image 1 of 1
    • Gently remove the speakers. Note that the wire connecting them may be lightly glued down. If so, gently pry up.
  4. Acer Aspire S3 MS2346 Battery Replacement, Battery: step 4, image 1 of 1
    • Gently lift the battery from the frame.
2 other people completed this guide.
Nikolas I Steckley
666 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 4,427
