Acer Aspire S3 MS2346 Motherboard Replacement
  1. Acer Aspire S3 MS2346 Motherboard Replacement, Back Cover: step 1, image 1 of 3 Acer Aspire S3 MS2346 Motherboard Replacement, Back Cover: step 1, image 2 of 3 Acer Aspire S3 MS2346 Motherboard Replacement, Back Cover: step 1, image 3 of 3
    • Remove the 12 5mm Phillips #00 screws.
    • Use a plastic opening tool to gently pry open the back panel.
    • Gently lift up the back panel, exposing the internals of the laptop.
  2. Acer Aspire S3 MS2346 Motherboard Replacement, Motherboard: step 2, image 1 of 3 Acer Aspire S3 MS2346 Motherboard Replacement, Motherboard: step 2, image 2 of 3 Acer Aspire S3 MS2346 Motherboard Replacement, Motherboard: step 2, image 3 of 3
    • Remove the motherboard connector cables by gently lifting the black latch that clamps them in place with a spudger or simply pull the connector from the port.
  3. Acer Aspire S3 MS2346 Motherboard Replacement: step 3, image 1 of 2 Acer Aspire S3 MS2346 Motherboard Replacement: step 3, image 2 of 2
    • Remove the 5 5mm PH0 screws holding the motherboard in place.
    • Gently remove the motherboard from the chassis.
  4. Acer Aspire S3 MS2346 Motherboard Replacement: step 4, image 1 of 1
    • Gently remove the motherboard.
Nikolas I Steckley
666 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 34
All Time: 3,436
