Acer Aspire S3-391-6046 Battery Replacement
  1. Acer Aspire S3-391-6046 Battery Replacement, Back Cover: step 1, image 1 of 1
    • Place laptop upside down.
  2. Acer Aspire S3-391-6046 Battery Replacement: step 2, image 1 of 2 Acer Aspire S3-391-6046 Battery Replacement: step 2, image 2 of 2
    • Remove the twelve 5mm screws with a Phillips #1 screwdriver.
  3. Acer Aspire S3-391-6046 Battery Replacement: step 3, image 1 of 1
    • Lift cover upwards away from you.
  4. Acer Aspire S3-391-6046 Battery Replacement, Battery: step 4, image 1 of 1
    • With the Phillips #1 screwdriver, remove the two 5mm screws located on either side of the battery.
  5. Acer Aspire S3-391-6046 Battery Replacement: step 5, image 1 of 2 Acer Aspire S3-391-6046 Battery Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Unplug the three white plugs from their sockets using tweezers by pinching the plugs and pulling them outwards.
    • Pulling with too much force will damage the plugs.
  6. Acer Aspire S3-391-6046 Battery Replacement: step 6, image 1 of 2 Acer Aspire S3-391-6046 Battery Replacement: step 6, image 2 of 2
    • Pull upwards on the plugs located on top of your battery until they have completely come off.
  7. Acer Aspire S3-391-6046 Battery Replacement: step 7, image 1 of 2 Acer Aspire S3-391-6046 Battery Replacement: step 7, image 2 of 2
    • Remove the electrical tape holding down the battery by peeling it upwards.
    • Grab the battery from the bottom and slide it out towards the direction of the bottom of the battery.
2 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 732
