Acer Aspire S3-391-6046 Fan Replacement
  1. Acer Aspire S3-391-6046 Fan Replacement, Back Cover: step 1, image 1 of 1
    • Place laptop upside down.
  2. Acer Aspire S3-391-6046 Fan Replacement: step 2, image 1 of 2 Acer Aspire S3-391-6046 Fan Replacement: step 2, image 2 of 2
    • Remove the twelve 5mm screws with a Phillips #1 screwdriver.
  3. Acer Aspire S3-391-6046 Fan Replacement: step 3, image 1 of 1
    • Lift cover upwards away from you.
  4. Acer Aspire S3-391-6046 Fan Replacement, Fan: step 4, image 1 of 1
    • Unscrew the three screws with a Phillips #0 screwdriver.
  5. Acer Aspire S3-391-6046 Fan Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Use either your hands or the tweezers to gently peel back the tape.
  6. Acer Aspire S3-391-6046 Fan Replacement: step 6, image 1 of 2 Acer Aspire S3-391-6046 Fan Replacement: step 6, image 2 of 2
    • Do not pull anything by the wires.
    • Use the tweezers to gently pull the small black plug out.
    • After the plug is out, you should be able to pull the fan assembly out.
Connor Talbot
99 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 591
