First, remove the 3 long torx t5 screws (red) and the 8 short ones (orange).
Once you have removed the screws, you can pry off the bottom panel.
Unplug the flex cable at the bottom left of the fan by flipping up the release tab and pulling. Also remove the two Philips #0 screws (red) securing the fan. The fan should then pull out without too much difficulty
Simply install the new fan in the opposite order that you removed the old one. Put everything back together and boot the computer. The new fan should now be working.
