Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement
  1. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Battery: step 1, image 1 of 1
    • Turn your laptop over, and find the laptop battery release button locks for your Acer laptop.
  2. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: step 2, image 1 of 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: step 2, image 2 of 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: step 2, image 3 of 3
    • Hold the battery release button, and pull the battery out of the laptop.
  3. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Fan: step 3, image 1 of 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Fan: step 3, image 2 of 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Fan: step 3, image 3 of 3
    • Remove battery before beginning.
    • Use a Phillips #0 screwdriver to remove the 5 screws from the bottom cover.
    • Pry open the cover using the Spudger tool.
  4. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: step 4, image 1 of 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: step 4, image 2 of 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: step 4, image 3 of 3
    • Remove the keyboard with a plastic opening tool or spudger.
    • There is a plastic film that needs to be gently peeled from the laptop base.
    • Use caution when removing the keyboard as it is fragile.
  5. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: step 5, image 1 of 2 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: step 5, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the 4 screws from the motherboard shield.
  6. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: step 6, image 1 of 2 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: step 6, image 2 of 2
    • Remove the motherboard from the base of the laptop by unscrew the screw drivers using PH0 mm Phillips Head.
    • Carefully remove the charger attachment in the top left.
  7. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: step 7, image 1 of 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: step 7, image 2 of 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement: step 7, image 3 of 3
    • Carefully remove the fan from the motherboard by detaching the plastic insert as seen in the pictures
  8. Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Bluetooth: step 8, image 1 of 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Bluetooth: step 8, image 2 of 3 Acer Aspire TimelineX 1830T-68U118 Bluetooth Replacement, Bluetooth: step 8, image 3 of 3
    • Detach the covered wires that connect the motherboard to the Bluetooth.
    • Remove the Bluetooth module by hand to then replace it.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 20
All Time: 785
