Acer Aspire TimelineX 4820T-6645 Wifi Module Replacement
  1. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement, Battery: step 1, image 1 of 1
    • Power down the laptop.
    • Turn the laptop over so the bottom is facing up and the battery is facing towards you.
  2. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: step 2, image 1 of 1
    • The tab on the right is a locking tab. Slide this tab to the right to unlock it (the red should now be showing).
    • Slide the left tab to the left and hold it there.
  3. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: step 3, image 1 of 2 Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: step 3, image 2 of 2
    • While holding the left tab to the left the battery should easily pull out of the laptop.
  4. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement, Wifi Module: step 4, image 1 of 2 Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement, Wifi Module: step 4, image 2 of 2
    • Flip the laptop over and remove screws (PH#1, 8mm length) holding the back cover in place
    • Remove back cover from your laptop
  5. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: step 5, image 1 of 2 Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: step 5, image 2 of 2
    • Disconnect the two antenna cables from the WLAN board as shown below
    • Black wire is terminal 1(left), white wire is terminal 2(right)
  6. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: step 6, image 1 of 1
    • Remove the screw(PH#1, 3mm length) holding the WLAN board to the laptop
  7. Acer Aspire TimelineX 4820T-6645  Wifi Module Replacement: step 7, image 1 of 1
    • Detach and remove the WLAN board from the WLAN socket
Dylan Bryda
109 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 236
