Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement
  1. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Power down the laptop.
    • Turn the laptop over so the bottom is facing up and the battery is facing towards you.
  2. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: step 2, image 1 of 1
    • The tab on the right is a locking tab. Slide this tab to the right to unlock it (the red should now be showing).
    • Slide the left tab to the left and hold it there.
  3. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: step 3, image 1 of 2 Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: step 3, image 2 of 2
    • While holding the left tab to the left the battery should easily pull out of the laptop.
  4. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Hard Drive: step 4, image 1 of 2 Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement, Hard Drive: step 4, image 2 of 2
    • Place laptop bottom side up, and use a Phillips #1 screwdriver to unscrew the five 8 mm screws from the back panel.
  5. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: step 5, image 1 of 1
    • After removing the back panel, use a Phillips #1 screwdriver to unscrew the two 8 mm screws that hold the retaining piece to the frame.
  6. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: step 6, image 1 of 2 Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: step 6, image 2 of 2
    • Pull the plastic tab toward the frame to disconnect the hard drive SATA.
  7. Acer Aspire TimelineX 4820T-6645 Hard Drive Replacement: step 7, image 1 of 1
    • Remove the hard drive from the laptop, and use a Phillips #1 screwdriver to unscrew the two 3 mm screws that secure the retaining piece to the hard drive.
Ian Smiley
109 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 600
