Introduction
This guide shows you how to replace your computer’s RAM, this is a short simple process that only requires 1 phillips head screwdriver to complete.
Power down the laptop.
Turn the laptop over so the bottom is facing up and the battery is facing towards you.
Flip the laptop over and locate the hard drive cover. This is a L shaped plastic cover and has 5 PH#1 8mm screws located around the outside edge. The screw locations are denoted by red circles in the figure.
Remove those five screws and then remove the cover.
