Acer Aspire V3-551-8887 Back Panel Replacement
  1. Acer Aspire V3-551-8887 Back Panel Replacement, Back Panel: step 1, image 1 of 1
    • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  2. Acer Aspire V3-551-8887 Back Panel Replacement: step 2, image 1 of 2 Acer Aspire V3-551-8887 Back Panel Replacement: step 2, image 2 of 2
    • Use a spudger to pry the panel up from the laptop case and remove it.
    • The laptop should now be open with the RAM and wifi chip now accessible.
Jacob Lesinski
143 Reputation
1 Guide authored
Cal Poly, Team 8-8, Regan Spring 2014 Member of Cal Poly, Team 8-8, Regan Spring 2014
CPSU-REGAN-S14S8G8
4 Members
7 Guides authored
One Comment
Is the hard drive accessible for replacement from the bottom? I see black stuff over the drive with the WIFI cables going underneath. Is that removable so one can access the drive from the bottom, or is it accessible from under the keyboard?
danwat1234 - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,785
