Acer Aspire V3-551-8887 RAM Replacement
  1. Acer Aspire V3-551-8887 RAM Replacement, Back Panel: step 1, image 1 of 1
    • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  2. Acer Aspire V3-551-8887 RAM Replacement: step 2, image 1 of 2 Acer Aspire V3-551-8887 RAM Replacement: step 2, image 2 of 2
    • Use a spudger to pry the panel up from the laptop case and remove it.
    • The laptop should now be open with the RAM and wifi chip now accessible.
  3. Acer Aspire V3-551-8887 RAM Replacement, RAM: step 3, image 1 of 1
    • Locate the two RAM clips.
  4. Acer Aspire V3-551-8887 RAM Replacement: step 4, image 1 of 1
    • Use two spudgers to pry the two clips outward to release the RAM chip.
  5. Acer Aspire V3-551-8887 RAM Replacement: step 5, image 1 of 1
    • Gently pull out the RAM chip.
    • If your laptop is using more than one stick of RAM, remove the second by repeating the past three steps.
Lance
656 Reputation
2 Guides authored
Cal Poly, Team 8-8, Regan Spring 2014 Member of Cal Poly, Team 8-8, Regan Spring 2014
CPSU-REGAN-S14S8G8
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 12,103
