Acer Aspire V5-122P-0468 Display Replacement
  1. Acer Aspire V5-122P-0468 Display Replacement, Battery: step 1, image 1 of 2 Acer Aspire V5-122P-0468 Display Replacement, Battery: step 1, image 2 of 2
    • Remove the nine 4mm screws with a PH0 screwdriver.
    • Remove the two 6mm screws with a PH0 screwdriver.
  2. Acer Aspire V5-122P-0468 Display Replacement: step 2, image 1 of 2 Acer Aspire V5-122P-0468 Display Replacement: step 2, image 2 of 2
    • Remove the black rubber tab on the back of the computer
    • Remove the 4mm screw hidden underneath the black tab with a PH0 screwdriver.
  3. Acer Aspire V5-122P-0468 Display Replacement: step 3, image 1 of 2 Acer Aspire V5-122P-0468 Display Replacement: step 3, image 2 of 2
    • Orient the computer upside down, with the hinges facing away from you.
    • Find the black plastic piece in the SD card slot on the right side of the computer.
    • Remove the plastic piece by sliding it out of the SD card slot.
  4. Acer Aspire V5-122P-0468 Display Replacement: step 4, image 1 of 3 Acer Aspire V5-122P-0468 Display Replacement: step 4, image 2 of 3 Acer Aspire V5-122P-0468 Display Replacement: step 4, image 3 of 3
    • Insert a spudger at these eight locations to disengage the plastic tabs from the housing cover, and pry apart.
    • Continue around the entire perimeter of the cover with the spudger.
    • Use a spudger to pry the cover around I/O ports.
  5. Acer Aspire V5-122P-0468 Display Replacement: step 5, image 1 of 3 Acer Aspire V5-122P-0468 Display Replacement: step 5, image 2 of 3 Acer Aspire V5-122P-0468 Display Replacement: step 5, image 3 of 3
    • Remove the two 4mm screws using a PH0 screwdriver.
    • Depress the tabs holding the battery with a spudger.
    • Disconnect the battery connector from the motherboard using a spudger.
    • Pull the battery up and away from the laptop to remove.
  6. Acer Aspire V5-122P-0468 Display Replacement, Display: step 6, image 1 of 2 Acer Aspire V5-122P-0468 Display Replacement, Display: step 6, image 2 of 2
    • Flip up the black locking tab on the ZIF connector, and pull out the ribbon cable.
  7. Acer Aspire V5-122P-0468 Display Replacement: step 7, image 1 of 2 Acer Aspire V5-122P-0468 Display Replacement: step 7, image 2 of 2
    • Wedge a spudger in between the plastic bezel frame and back cover to create a gap.
    • Then insert a plastic opening tool to pry apart the bezel from the back cover.
    • Work your way around the perimeter of the cover with the plastic opening tool.
  8. Acer Aspire V5-122P-0468 Display Replacement: step 8, image 1 of 2 Acer Aspire V5-122P-0468 Display Replacement: step 8, image 2 of 2
    • Open up the laptop to unsnap the hinges from the back of the computer.
    • Slide the pin connector and cable through the hinge that connects the display to the rest of the laptop.
  9. Acer Aspire V5-122P-0468 Display Replacement: step 9, image 1 of 2 Acer Aspire V5-122P-0468 Display Replacement: step 9, image 2 of 2
    • Remove the transparent tape covering the pin connector.
    • Unplug the pin connector from the display.
  10. Acer Aspire V5-122P-0468 Display Replacement: step 10, image 1 of 1
    • Cut the tape between the display and the plastic frame using the flat end of a spudger.
    • Work the spudger around the perimeter of the display to separate it from the bezel.
    • The display is attached with a strong adhesive. Applying heat with a hairdryer or heat gun may make the removal process easier.
2 other people completed this guide.
Nat McCormick
801 Reputation
5 Guides authored
USF Tampa, Team S16-G1, Boczar Spring 2018 Member of USF Tampa, Team S16-G1, Boczar Spring 2018
USFT-BOCZAR-S18S16G1
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 1,050
