Acer Aspire V5-131-2629 Cover Replacement
  1. Acer Aspire V5-131-2629 Cover Replacement, Battery: step 1, image 1 of 1
    • Carefully turn your Acer Aspire V5-131-2629 upside down, so that the battery cell is visible and nearest to you.
  2. Acer Aspire V5-131-2629 Cover Replacement: step 2, image 1 of 1
    • Identify the small, oval slide switch on the left hand side of the laptop, directly above the battery.
  3. Acer Aspire V5-131-2629 Cover Replacement: step 3, image 1 of 1
    • Insert an opening tool into the hole on the right side of the oval switch. Use the opening tool to slide the switch to the right.
  4. Acer Aspire V5-131-2629 Cover Replacement: step 4, image 1 of 2 Acer Aspire V5-131-2629 Cover Replacement: step 4, image 2 of 2
    • With the switch engaged to the right, firmly pull the battery out and towards yourself, parallel to your work surface.
  5. Acer Aspire V5-131-2629 Cover Replacement, Cover: step 5, image 1 of 1
    • Remove the single Phillips #0 screw from the cover on the underside of the laptop.
  6. Acer Aspire V5-131-2629 Cover Replacement: step 6, image 1 of 2 Acer Aspire V5-131-2629 Cover Replacement: step 6, image 2 of 2
    • Remove the cover by sliding it outwards and remove it from the device.
Aaron Almeida
551 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 17
All Time: 595
