Acer Aspire V5-131-2680 Battery Replacement
  1. Acer Aspire V5-131-2680 Battery Replacement, Battery: step 1, image 1 of 1
    • Make sure your laptop is powered down and completely closed before proceeding.
    • Turn your laptop upside down. The stickers should be facing up.
  2. Acer Aspire V5-131-2680 Battery Replacement: step 2, image 1 of 2 Acer Aspire V5-131-2680 Battery Replacement: step 2, image 2 of 2
    • To open the bottom compartment, put one finger underneath the laptop and firmly grab the compartment with your thumb.
    • You can also use both thumbs for more pressure.
    • Carefully slide the bottom compartment with your thumb until you feel it pop out of place.
  3. Acer Aspire V5-131-2680 Battery Replacement: step 3, image 1 of 2 Acer Aspire V5-131-2680 Battery Replacement: step 3, image 2 of 2
    • In front of the battery, you will find a sliding flap. This is a battery-release lock.
    • Place your finger on the latch and slide the latch to open. Pull out the battery from its compartment.
    • Do not remove your finger from the latch while sliding the battery out.
    • Once the battery is out, release the latch.
Naomi Zaldana
147 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 223
