Acer Aspire V5-473P-5602 Screen Replacement
  1. Acer Aspire V5-473P-5602 Screen Replacement, Screen: step 1, image 1 of 2 Acer Aspire V5-473P-5602 Screen Replacement, Screen: step 1, image 2 of 2
    • Place a suction cup on the screen.
    • Insert an iFixit opening tool into the plastic bezel frame.
    • Work your way around slowly until the bezel is removed.
  2. Acer Aspire V5-473P-5602 Screen Replacement: step 2, image 1 of 3 Acer Aspire V5-473P-5602 Screen Replacement: step 2, image 2 of 3 Acer Aspire V5-473P-5602 Screen Replacement: step 2, image 3 of 3
    • Detach the three different connectors located on the back of the screen.
  3. Acer Aspire V5-473P-5602 Screen Replacement: step 3, image 1 of 1
    • To remove the screen from the bezel frame, cut the tape around the display using a spudger.
    • The screen is attached with a strong adhesive tape. Applying heat may make the removal process easier.
Patricio Valdés
97 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 16
All Time: 588
