Acer Aspire V5-473P-5602 Touchpad Replacement
  1. Acer Aspire V5-473P-5602 Touchpad Replacement, Back Panel: step 1, image 1 of 2 Acer Aspire V5-473P-5602 Touchpad Replacement, Back Panel: step 1, image 2 of 2
    • Flip the laptop over so the back panel is facing upwards.
    • Use the Phillips #0 screwdriver to remove seventeen 2.5mm screws.
    • Remove the back panel from the laptop using an iFixit opening tool.
  2. Acer Aspire V5-473P-5602 Touchpad Replacement, Battery: step 2, image 1 of 2 Acer Aspire V5-473P-5602 Touchpad Replacement, Battery: step 2, image 2 of 2
    • Remove the Phillips #0 screw from the middle of the battery.
  3. Acer Aspire V5-473P-5602 Touchpad Replacement: step 3, image 1 of 1
    • Unplug the battery from the motherboard.
  4. Acer Aspire V5-473P-5602 Touchpad Replacement: step 4, image 1 of 1
    • Carefully take the battery out of the device.
  5. Acer Aspire V5-473P-5602 Touchpad Replacement, Touchpad: step 5, image 1 of 1
    • Use a spudger to remove the aluminum foil tape from the touchpad.
  6. Acer Aspire V5-473P-5602 Touchpad Replacement: step 6, image 1 of 1
    • Unplug the cable from the touchpad.
  7. Acer Aspire V5-473P-5602 Touchpad Replacement: step 7, image 1 of 1
    • Remove ten Phillips #0 screws securing the touchpad to the base.
  8. Acer Aspire V5-473P-5602 Touchpad Replacement: step 8, image 1 of 1
    • Use the pointed end of a spudger to remove the small triangular metal piece.
  9. Acer Aspire V5-473P-5602 Touchpad Replacement: step 9, image 1 of 2 Acer Aspire V5-473P-5602 Touchpad Replacement: step 9, image 2 of 2
    • Use the spudger to lift up the touchpad carefully.
    • Remember to use electronic cleaner to clean the touchpad screen surface before placing the new touchpad back in.
Thuy Tran
267 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 342
