Acer Aspire V5-571 Mother Board Replacement
Video Overview
  1. Acer Aspire V5-571 Mother Board Replacement, Keyboard: step 1, image 1 of 3 Acer Aspire V5-571 Mother Board Replacement, Keyboard: step 1, image 2 of 3 Acer Aspire V5-571 Mother Board Replacement, Keyboard: step 1, image 3 of 3
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Mother Board Replacement: step 2, image 1 of 3 Acer Aspire V5-571 Mother Board Replacement: step 2, image 2 of 3 Acer Aspire V5-571 Mother Board Replacement: step 2, image 3 of 3
  3. Acer Aspire V5-571 Mother Board Replacement, Optical Drive: step 3, image 1 of 3 Acer Aspire V5-571 Mother Board Replacement, Optical Drive: step 3, image 2 of 3 Acer Aspire V5-571 Mother Board Replacement, Optical Drive: step 3, image 3 of 3
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  4. Acer Aspire V5-571 Mother Board Replacement, Upper  Cover: step 4, image 1 of 3 Acer Aspire V5-571 Mother Board Replacement, Upper  Cover: step 4, image 2 of 3 Acer Aspire V5-571 Mother Board Replacement, Upper  Cover: step 4, image 3 of 3
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  5. Acer Aspire V5-571 Mother Board Replacement: step 5, image 1 of 3 Acer Aspire V5-571 Mother Board Replacement: step 5, image 2 of 3 Acer Aspire V5-571 Mother Board Replacement: step 5, image 3 of 3
    • Carefully separate the upper cover and remove it.
  6. Acer Aspire V5-571 Mother Board Replacement, HDD (Hard Disk Drive): step 6, image 1 of 3 Acer Aspire V5-571 Mother Board Replacement, HDD (Hard Disk Drive): step 6, image 2 of 3 Acer Aspire V5-571 Mother Board Replacement, HDD (Hard Disk Drive): step 6, image 3 of 3
  7. Acer Aspire V5-571 Mother Board Replacement, Wi-Fi Half Mini PCIe card: step 7, image 1 of 2 Acer Aspire V5-571 Mother Board Replacement, Wi-Fi Half Mini PCIe card: step 7, image 2 of 2
    • Remove one Phillips screw, securing th WLan card and disconnect the two coaxial antenna cables.
    • Remove the Wi-Fi card.
  8. Acer Aspire V5-571 Mother Board Replacement, Mother Board: step 8, image 1 of 3 Acer Aspire V5-571 Mother Board Replacement, Mother Board: step 8, image 2 of 3 Acer Aspire V5-571 Mother Board Replacement, Mother Board: step 8, image 3 of 3
    • Remove the Memory Cover.
    • Disconnect the Loudspeaker cable connector.
  9. Acer Aspire V5-571 Mother Board Replacement: step 9, image 1 of 3 Acer Aspire V5-571 Mother Board Replacement: step 9, image 2 of 3 Acer Aspire V5-571 Mother Board Replacement: step 9, image 3 of 3
    • Remove two Phillips screw from the Mother board and from the Optical drive SATA adapter.
    • Disconnect the LCD Display flex cable.
    • Disconnect the DC Jack cable.
    • Carefully remove the Optical drive SATA adapter.
    • We will disconnect the battery cable when we pick up the board.
  10. Acer Aspire V5-571 Mother Board Replacement: step 10, image 1 of 3 Acer Aspire V5-571 Mother Board Replacement: step 10, image 2 of 3 Acer Aspire V5-571 Mother Board Replacement: step 10, image 3 of 3
    • Carefully pick up the Mother board and disconnect the Battery cable.
3 other people completed this guide.
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
One Comment
I can’t seem to get the system to reboot after replacing two motherboards. Is there a little trick about replacing or reseating the motherboard properly? Is the black cloth tape over the fan exhaust important?
Fun Fong - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 13
All Time: 4,368
